Tagged: 2D, ansys-mechanical, ansys-workbench, mechanical, static-structural
March 11, 2021 at 5:31 am
ben_cv
SubscriberHello community !nnI'm asking myself how to model the weld (or connection) between adjacent beams ?nMy problem : nI have a storage rack (gaz bottles or others) and each cell is modelled with beam 1d element, and each cells is welded to adjacent one in both x-y directions.nBut I cannot find the correct way to model the connections between the cells.nWith 2d shell there is no problem, but i would like using only 1d elements.nnThanks a lot for your help !n -
March 12, 2021 at 5:58 am
1shan
Ansys Employee,nCould you share an image of your model and tell what the objective is? The general practice is to use shell elements to model welds. You could model the rack using 1D elements but the weld stiffness (and other related effects) won't be considered. This is preferable in cases where the weld effects are not significant and the overall structure deformations/stresses are needed. You could always add beams in between to connect 2 beams (I don't see the point of using a connection). You could check this tutorial series describing a 1D analysis of a space frame.nRegards,nIshan.n
Trending discussions
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
Top Contributors
2656
2120
1349
1118
461
Top Rated Tags
