November 20, 2023 at 2:37 pm
Blessing Ojo
SubscriberI'll like to know how to make adjustments to the dimensions of an imported object in HFSS or do i have to recreate the object from scratch?
November 21, 2023 at 6:19 pm
Praneeth
Forum ModeratorHi Blessing.
Thank you for reaching out to the Ansys Learning Forum.
It looks like you have submitted a case on the same issue and it is being addressed there. So, I will close this topic for further replies.
Please note that you can open this question again if the issue is not resolved.
Best regards,
Praneeth.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3155
1688
1478
