December 3, 2020 at 5:48 pm
ebone2god
SubscriberHi all,I have an APDL .db model that I need to make some geometry updates and add some components to. I'm not familiar with modeling in APDL, so I would like to import the APDL model into workbench and add/adjust the geometry using SpaceClaim. The issue that I am having is that, when using the External Model command to bring in the .cbd file created using APDL, I am not given any options to modify the geometry. An alternative option would be to create the necessary additional parts separately, then merge them with the imported APDL model and add the necessary constraints/connections; however, I'm not sure how to go about this.nI would be grateful for any suggestions anybody has on how I can modify an APDL geometry within Workbench!n -
December 5, 2020 at 2:32 pm
SubscribernUse External Model to bring in the existing mesh, use a Mechanical Model to bring in new Geometry and mesh it, then bring those two together in another Mechanical Model where you can reposition each mesh as needed and finally, bring that into a Static Structural to add loads and boundary conditions and solve.nn
December 5, 2020 at 7:34 pm
ebone2god
SubscriberPerfect - thanks very much for the feedback!n
- The topic ‘How to Modify Geometry from APDL in Workbench?’ is closed to new replies.
- Floating point exception
- How to indetify baffles in Fluent meshing
- How to delete elements on Ansys Workbench
- Meshing cylindrical bodies with holes
- Quality failure limits are exceeded on some solid bodies… in ansys meshing
- Problems in the meshing of my geometry
- Ansys Mechanical – Python Scripting – Access and input parameter
- Fluent Meshing Batch Mode – Problems workflow commands
- Local mesh refinement with targeted edge lengths at specified areas
- Mesh Element Quality Display Style Not Showing
8808
4658
3153
1680
1470
