How to monitor a velocity profile
    • Walaa
      when I am selecting a monitor for velocity
      I want to get velocity profiles in different sections
      which choice should i made ?
    • Vishal Ganore
      If you wish to see the velocity profiles at different sections then run the model first and then create a line body (Post-Processing-Surface-Line/Rake). Once you create a line body at different sections in your geometry, it will appear for selection under X-Y plot. Monitoring any parameter at sections will give you averaged/integrated value (number), I believe that will help you to create profiles?
    • Walaa
      Thanks Vganore, I will try this.
