Platform
Platform
How to move duplicated ansys project position in workbench GUI
    • Rashi
      Hi all,
      I have particular simulation, which I'm changing several variable of a model. In this particular case I cannot use "parameters" to do the simulation in single mechanical project.
      So what I did was create one mechanical project and duplicate it and do the required changes. From this I have created several projects in single workbench file.
      The thing is when ANSYS duplicates the project it places it in the GUI where it prefers. And this position cannot be changed in the GUI, so when there is many project files its hard to track all the projects.
      So is there any way change the positions of the ANSYS project in workbench GUI?
      Thanks in Advance.
    • Keyur Kanade
      You can select the the cell system or cell with left mouse button. Keep mouse button pressed. Then move it or say drag it to desired position.
      You can also rename the cells
      Keyur
      Also, please like the answers which have helped you move forward and in the end, once your issue is resolved, please mark the most appropriate solution (most useful advice) as 'Is Solution'. This will help others who are using this thread to find answers to similar questions.
    • Rashi
      Thank you for your reply. All this time I've tried to move the cell by clicking on the Cell name "A, B, C, D....."  that's why it didn't move. I selected "Static Structural" the cell system then I was able to move it!
    • Keyur Kanade
      Glad that you issue is resolved.
      Keyur
    • soumitra2102
      Thanks @kkanade,
      I was also doing the same thing,- trying to drag by clicking on the A, B, C,...cell names.
      Thanks.
Viewing 4 reply threads
