how to obtain a half model from full model in spaceclaim
    • MarkFei
      How can I obtain a half model from full model in spaceclaim, just like the symmetry feature in DesignModeler?n
    • peteroznewman
      I'm using SpaceClaim in ANSYS 2020 R1 and I haven't found the kind of automation that DesignModeler provides for including symmetry.nI just make a plane, and use the Split Body tool to cut a body in half. If you have several bodies, I select them one after another. I haven't found the split body tool works on multiple bodies at once.nAfter the geometry has been imported to Mechanical, there is a Symmetry Region, but I will often create a Displacement BC to create the symmetry boundary condition.n
    • MarkFei
      Thank you sir, I have figured it outn
    • mechE
      Can you please explain how you fiigured it out?
Viewing 3 reply threads
  • The topic ‘how to obtain a half model from full model in spaceclaim’ is closed to new replies.
