Ansys Products
Ansys Products
How to obtain a Lumerical evaluation license
    • Lito Yap
      This outlines the process to obtain an evaluation/trial license from the Lumerical Launcher 2021 R1 release.n1) Download and install the Lumerical simulation suite into a supported Windows PC. n2) Select 'Lumerical (Standard)' in the Floating > License manager selection and 'localhost' as Server.nThe 30 day evaluation license required for the selected example will be downloaded and activated on your PC. If you want to try a different example, the Obtain license button will be enabled if you do not have the license required for the example. Simply Obtain the license for the example and download the files.n
    • Keyur Kanade
      Thanks!n
