February 2, 2021 at 6:30 pm
iurrutia024
Subscriberi need to evaluate the movement obtained on a vehicle chassis apliying a force simulating the motor vibration on an harmonic study, and then combine this results with a response spectrum studies where I apply the acceleration generated by the road. My combined result for acceleration is like this.
February 3, 2021 at 8:05 pmDave Looman
Ansys EmployeeThis can be done with a Solution Combination. Right click on Model at the top of the tree and insert> Solution Combination. You should use an SRSS combination as shown below. Specify the harmonic frequency you want to combine with the response spectrum results and use an SRSS combination as shown below. Since the harmonic results are signed quantities the negative values would cancel with the unsigned response spectrum results so SRSS avoids that.nn
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
5162
3275
2453
