March 10, 2022 at 8:23 am
svrk458
SubscriberHi, I am working on metamaterial absorbers. I need to verify the polarization sensitivity of the structure. I request you to provide the procedure to get TE and TM polarization characteristics in HFSS
March 14, 2022 at 11:35 amChinmay T
Ansys EmployeePlease use the floquet port for your simulation model.
Refer to the Split Ring Resonator metamaterial example model and its help document from HFSS examples for more details.
Thanks Chinmay
- Maxwell, HFSS or Q3D?
- Error
2534
2066
1285
1104
459
