November 11, 2019 at 9:19 am
Tayyaba
SubscriberHi everyone,
I hope you are doing well, I want to open result file 'file.rst' which is usually saved from workbench FSI simulation in
dp0-SYS-MECH
I have to work with it in workbench because I need to have deformation data from it, but workbench supports only .wbpj format. Although I can open .rst format in CFD post but from there i cannot get the values of any property (deformation )verses time.
Is there any way of doing this?
Regards
Tayyaba
November 12, 2019 at 1:20 pm
November 12, 2019 at 2:31 pm
November 13, 2019 at 7:13 am
sathya
SubscriberHi,
Click on Solution tab and Try again.
Make sure the rst file corresponds to the workbench setup.
November 13, 2019 at 10:03 am
March 11, 2020 at 1:36 pm
kaitova
SubscriberI suggest to clear generated data first, it helps
March 20, 2020 at 3:35 pm
kaitova
SubscriberHi Sathya.
can you please advise if it is possible to open rst file in the new(empty) WB Mechanical model? Or it should be only in the model that includes the set up for the analysis?
Thank you in advance,
3419
2473
1310
1022
