July 24, 2018 at 10:06 am
Mrjiang
Subscriberi want to export the script/command that ansys has behind the software when I am using WB to create my model. I was only able to record the script but it doesn't give more information or details about what I am actually doing in each workspace. I did a small search and found that "SendCommand" can help me export more information compare to recording the script but I couldn't find how to operate it. Does anyone have a clue of how to export more script/command from ansys WB?
August 5, 2018 at 4:15 pm
Karthik R
AdministratorHello,
Thank you for your question. Have you looked into the WorkBench Users Guide? I'd like to particularly point you to the section on 'Using Journals and Scripts'. There is a specific section on 'Recording and Playing a Journal'. I hope this helps you in your purpose.
Thank you.
Best Regards,
Karthik
August 31, 2018 at 10:08 am
jthuong
Ansys Employee@Kremella: This question does not seem to be related to "Embedded Systems" so maybe it could be relocated to the correct category? Maybe Systems?
- legend min and max
- Ensight hot iron palette from an image
- Crash with Exit code 1073741819
- older version
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- What are the OpenGL drivers supported by SCADE Display KCG?
- What are the target language supported by the SCADE code generators?
- FLUENT APPLICATIION ERROR
- save data error
2706
2138
1355
1144
462
