November 9, 2018 at 10:13 pm
sana ullah
SubscriberHI I am trying to optimise a machine at two different speeds with different temperature of the Permanent magnets at each speed, i am not sure how will i define a certain tmeprature variable for each speed in optimisation or optimetric parameters? Can any help please ?
November 12, 2018 at 3:44 pm
mgardner
SubscriberThe simplest approach would probably be to define two different magnet materials based on the different properties of the magnet at your temperatures of interest. Use one of the magnet materials for the simulation at one speed, and use the second magnet material for the simulation at the other speed. This might require making two separate designs.
November 12, 2018 at 4:12 pm
sana ullah
SubscriberHI mgardner, thanks for the suggestion, however, there is an issue, both conditions are dependent on each other. The machine should achieve the first target ( which is a high magnet temperature region) before it finds out the objective function at the lower magnet temperature. SO a single design should have both the conditions, otherwise i can't use the objective function on two separate designs which are totally independent of each other.
regards
- Maxwell, HFSS or Q3D?
- Error
2706
2142
1355
1144
462
