3D Design
3D Design
How to parameterize 2D sketching plane in Spaceclaim
    • sagar.gupta.satrasala
      I am trying to parameterize the 2D plane dimensions in Spaceclaim. Could someone tell me how to do it.
    • peteroznewman
      It's not clear what you want. I made a video that shows how to make parameters in SpaceClaim for use in a Mechanical model.
      Yes, I actually followed this video for parametrization. In this video, they showed how to parametrize the height of the circular portion. I want to know about paramerization of the diameter of that circle.
    • peteroznewman
      That is my video you followed.
      In SpaceClaim, I have a rectangular surface with a hole in it.
      Use the Pull Tool to pull the edge of the hole in a radial direction. Select the Ruler from the Options for Pull. Measure from the center of the circle, and click the P button to make it a Parameter.
      Give the Group a better name.
Viewing 3 reply threads
  • The topic ‘How to parameterize 2D sketching plane in Spaceclaim’ is closed to new replies.
