June 12, 2023 at 2:08 pm
Patryk Sienkiewicz
SubscriberHello,
I am trying to set material assignment for one of the objects as parameter for the DOE.
I set it in Parameter Set and it's all good:
But it doesn't appear nowhere in the DOE, also when I import Design Points from Parameter Set it imports only half of them (one half is Titanium, other is PEEK).
How can I set it properly so all of the Design Points will be visible in the DOE?
June 19, 2023 at 12:54 pm
Ashish Kumar
Forum ModeratorHi,
Please see if the following links help you:
Parameterize Material Assignments (ansys.com)
Parametrizing Material properties (ansys.com)
Parameterize ANSYS Mechanical material assignments
Ashish Khemka
4476
2957
1433
1322
