How to perform harmonic response in Static Structural with dampers?
    • Luca_Patriarchi
      Hi all,
      I am tring to perform a hamronic response of a structure using, as dampers, four springs attached to the basement. The problem is that a message comes out writing
      "The system is solved without damping. This may cause very large peak harmonic responses around natural frequencies due to resonance".
      How may I fix it?
    • Ashish Khemka
      Forum Moderator
      In harmonic response analysis - you can define damping under the details of analysis settings as indicated below:
      Regards Ashish Khemka
