TAGGED: boundary-layer-elements, fsi, remeshing, species-diffusion
May 16, 2022 at 11:35 am
Rick17
SubscriberHi,
I am trying to perform an FSI simulation in Fluent. The problem that I am currently working on is that when the walls undergo large deformation, the boundary layer elements become distorted and the simulation stops because of the negative volume elements error. Is there any way to maintain a good quality of boundary layer elements other than adjusting the diffusion parameter?
Thank you.
May 17, 2022 at 5:57 amKeyur Kanade
Ansys EmployeeYou may want to change inflation parameters.
Please check following videos
Ansys Meshing: Inflation:
https://www.youtube.com/watch?v=lrEHXizrhC0
If possible, you can remove inflation and use only tet or hex elements.
Regards Keyur
May 17, 2022 at 3:48 pmRick17
Got it! Thank you very much for your help.
Kind regards
Viewing 2 reply threads- The topic ‘How to perform remeshing for 3D boundary layer elements’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3155
1688
1478
