February 14, 2022 at 8:12 am
Hwong
SubscriberHey guys,how to plot a contour with user defined stress range.Just make the contour below do not display the elements in freeze area? Thank you guys, don’t care my poor english pls.and this is nodal solution
February 14, 2022 at 8:34 amSurya
Please refer to this help documentation on how to change the legend in Mechanical APDL - 11.3. Controlling Miscellaneous Text and Symbols (ansys.com)
Thanks Surya
How to access the ANSYS Online Help ÔÇö Ansys Learning Forum
Rules & Guidelines ÔÇö Ansys Learning Forum
February 14, 2022 at 9:35 amHwong
Subscriberthanks but my means is not change the legends or something, I need to hide the elements which stress value exceed my range when I plot contour . Maybe it is a difficult issue to fix
February 14, 2022 at 10:42 ampeteroznewman
SubscriberUse the Capped Isosurface plot. In the link below, I am showing how to plot elements above a threshold, but you can use it to plot elements below a threshold.
https://forum.ansys.com/discussion/6503/contour-band-with-a-user-defined-max-min-value
3778
2575
1825
1242
598
