Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
How to plot a specific magnetic field component such as Hx?
    • linshengz
      Hello,nI am working on a project and trying to understand the magnetic field distribution in the near field range. And I am confused if I can plot the magnetic field component separately, such as Hx, Hy, and Hz at a given point?nRegards.n
    • Praneeth
      nAre you trying to plot the fields using the near field region?nPlease provide more inputs to help us serve you better.nBest Regards,n
    • AndyJP
      Create a surface, or use an existing surface or object. select it and choose (RMB)Plot Field->named expression.nThe expression is created in the Field calculator (Field overlays-(RMB)->Calculator). There is a manual and a few samples on field calculator in the help library.n
