Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
How to plot air gap magnetic flux density in different axis and different plane
    • phuonganhlovely.me
      Hi guys!
      I have simulation (magnetostatic type) a surface mounted PM spherical motor, i want to plot the magnetic flux density in different axis (x,y,z) and different plane (xy, xz, yz, xyz) to evaluation the magnetic flux density ? my method to plot the x,y,z axis is i draw 3 circel in 3 axis at the air gap and used fields calculator to plot the magnetic flux density. it is true method ? and i have no idea to do for the plane.
      I am really appriciate with any idea or advice for tthe solution. Thank you so much.
      B_z is the circel z axis
      B_x is the circel x axis
      B_y is the circel y axis
    • DELI
      Hi, you can plot Bx, By and Bz on the geometry by: Selecting desired geometry->Maxwell 2D/3D->Fields->Named Expression->Bx/By/Bz The geometry could be a point, a line, an object or a plane.
      thank a lot for your reply
      the spherical rotor how can i draw the line or circle if i want to plot air gap magnetic flux density in the z axis or the plane also for the other axis, plane and special for the XYZ plane.
      Thanks in advance
