March 25, 2021 at 11:00 pm
KaKasha
SubscriberI create a UHPFRC beam and add the following data to specify it's behavior (Density=2440 kg/m3, Young's Modulus=45000MPa, Poisson's Ratio = 0.21, Tensile Yield Strength=3MPa, Compressive Yield Strength=130MPa, Tensile Ultimate Strength=8.5MPa, Compressive Ultimate Strength=160MPa), and for multi-linear isotropic hardening (strain=0,0.0001,0.0002,0.0003,0.0004,0.0005, stress= 135, 138, 141, 144, 147, 150 MPa respectively) I create a face meshing of 5mm, and for static structure: create a fixed support at bottom left and a frictionless support at bottom right. For the displacement, I create a boundary displacement in the mid top of the model. As a solution, I asked for total deformation and force reaction at the same boundary, fixed support, top face geometry.nTh want my graph to look like this e gBut raph that I get for is not realistic, and when displacement is coming back to zero I get some weird lines as I have marked in read. nwhat essentials data should I add to engineering data?nis there any other way to plot deformation vs force?n -
March 26, 2021 at 5:43 am
1shan
Ansys Employee,nI cannot see the inserted images. Please make sure you have added them.nnRegards,nIshan.n n -
March 26, 2021 at 1:08 pm
Trending discussions
Top Contributors
2508
2064
1277
1088
456
Top Rated Tags
