Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
How to plot eye diagram in Electronics Desktop? (single-ended signal)
    • jihye
      Hello. I'm trying to plot eye diagram(single-ended signal) in Electronics Desktop but some error occurs.nI made a circuit then 'Add Nexxim Solution Setup>Transient Analysis' analyze it successfully analyzed.nnBut, If I choose AMI Analysis, Quick Eye Anaylysis 'Line ends in the middle of an expression' error occurs.nSo, I tried another method. In Transient Alaysis I added eye probe but 'Line ends in the middle of a n expression' error occurs again.nnI don't know what is the problem, since the lines are all connected. I need a help... n n
    • Praneeth
      nThank you for reaching to us. Please specify which tool under Electronics Desktop and its version number that you are using for your simulations. If possible, kindly attach screen shots of the error messages from the message window and any other details which can help us serve you better.nAll the best.nBest Regards,n
