Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
How to plot field overlay of X component of Mag_B?
    • H2020
      I am trying to see the magnetic field distribution on a sheet for a simulation model right now. However, the Mag_B that is plotted contains all components. Is there a way to only plot Mag_B with the X, Y or Z component?
      best,
      H2020
    • Navya C
      you can create a polyline as the circular path (OR any path you want) first -> use field calculator to create named expression Bx
      In field calculator, Input: Quantity->B
      Vector: Scalar?->ScalarX
      Add..->Type the name as "Bx"
      Create a field report-> select the circle(or the path you crated) in geometry ->add Bx from Calculator Expressions->New report
      Regards Navya
    • H2020
      Thanks for the reply. I followed your instructions and plotted a field overview of the scalar X component. Is is necessary to apply the smooth() and Mag() commands to your code as well? Since those are the operators used on the Mag_B expression as well.
      Best H2020
  • The topic ‘How to plot field overlay of X component of Mag_B?’ is closed to new replies.
