March 22, 2021 at 6:12 pm
clabr
SubscriberHi everyone
I would need to do something like this in post-processing :
March 22, 2021 at 6:29 pmYasserSelima
Subscriberyes .. you can do it in Fluent. Not sure about the post CFDnMarch 22, 2021 at 10:48 pmclabr
SubscriberThank you, could you explain how to do that on Fluent?nMarch 23, 2021 at 12:16 amYasserSelima
Subscriberfrom the left menu under results, select vectors ... and from the bottom, new surface , and create new surface for plotting .nFor pathline because they will not stick to the surface, you can only start the pathline from the surface and see where they endnMarch 23, 2021 at 12:17 amYasserSelima
SubscriberAnd by the way, the figure you are posting shows contours ... not vectors nor pathlinesnViewing 4 reply threads- You must be logged in to reply to this topic.
2524
2066
1279
1096
459
