July 11, 2019 at 9:40 am
HungNguyen
SubscriberHello,
My simulation is very simple. Heat source in water chamber which is on top of body structure. And power is provided into it and the temperature distribution is monitored. Power is delivered as a pulse.
I would like to make a graph of temperature in a specific location as a function of time.
How I specify the location (Edge or Surface or Point) and How I generate the temperature graph as a function of time?
Many Thanks in Advance. -
July 11, 2019 at 10:50 am
Ansys EmployeeWhich solver are you using?
July 12, 2019 at 2:36 am
HungNguyen
SubscriberI'm using multiphase model.
July 12, 2019 at 7:06 am
DrAmine
Ansys EmployeeYou define the Line in Fluent for example.
Then create XY Plot and you plot the Static Temperature along that line.Check XY Plots of Solution Data in User's Guide.
July 13, 2019 at 2:09 am
HungNguyen
Subscriberoh, will check that out. Thank you
HungNguyen
3744
2573
1793
1236
594
