How to plot the coordinate systems of solution, element, and node in Workbench
    • Haiquan
      Hello
      I use solid elements, are the coordinate systems of solution, element, and node the same with global coordinate systems?
      Thank you!
    • Chandra Sekaran
      Usually the default is for nodal coordinate systems and element coordinate systems(for solid element types) is parallel to global Cartesian system unless you rotate them. You can view the various coordinate systems by using the below:
      • Haiquan
        Thank you very much for your quick feedback
