August 18, 2022 at 11:20 pm
d.jemoronm
SubscriberHello
I'm working demagnetization of PMSG and the interst is to know how the B in the airgap. The problem is when I ploting by means with a "polyline" like "arc" in the axis x Maxwell use the distance, and I don't know hot to change the distance by angle in degrees.
The question is how to plot the normal magnetic induction B in degrees?
Somebody can help me?
August 18, 2022 at 11:21 pm
August 24, 2022 at 9:28 pm
GLUO
Ansys EmployeeHello @d.jemoronm,
The distuance is just the length of your arc. You could directly re-scale your x-axis from 0-245 mm to 0-360 degree.
GL
August 26, 2022 at 10:57 pm
- Maxwell, HFSS or Q3D?
- Error
5290
3311
2471
