August 16, 2022 at 9:27 am
shitizsehgal
SubscriberHi,
I am sorry if this post is shown twice on your feed. My question is about correctly accounting the energy source term in a VOF simulation. My query is as follows:
- When using a UDF (DEFINE_SOURCE) for prescribing energy source, is it mandatory to select /solve/set/multiphase-numerics/heat-mass-transfer/alternative-energy-source-treatment? to yes ( or can it stay to the default value of [no]). Please help me understand the purpose of this command line or the alternative treatment.
- I have latent heat value with me, which is 2706.2 kj/kg. Now should I prescribe it in the material properties of the vapor phase by converting it to kmol units there? I am guessing not, because I am using DEFINE_SOURCE to precribe the energy source. So, in that case
- what would be the appropriate units for latent heat in the UDF (kj/kg) or something else? I am currently using J/kg because that coupled with other terms (mass source term) gives me W/m^3 as the units for the energy source. I just want to be sure about what I am doing.
- Also, what should i prescribe in the material properties for standard state enthalpy of vapor? (0?)
Thank you,
Shitiz Sehgal
August 16, 2022 at 2:34 pm
Ansys EmployeeSource terms are assigned to the CELL ZONE, and are mass/heat/momentum etc per unit volume, so some care is needed to make sure you add the correct amount of material.
No need to alter the alternative treatment, as to what it does, check the manual https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/flu_ug/flu_ug_sec_mphase_massxfr.html%23flu_ug_sec_mphase_massxfr_altern_e
August 18, 2022 at 6:09 pm
shitizsehgal
SubscriberHi Rob,
Thanks for your response, but the link that you shared requires me to register as a customer. I am not able to access the information beyond the registration.
Also, I am still not sure about the units of latent heat in DEFINE_SOURCE. Is it going to be in kj/kg or j/kg or something else? Can you please clarify?
Thanks,
Shitiz Sehgal
August 19, 2022 at 3:16 pm
Ansys EmployeeClick on Help in the solver, when the browser opens copy the link into another tab.
The source term is for energy, it's for you to work out how much to add. If you're modelling phase change you may want to look at the Fluent multiphase models.
August 29, 2022 at 12:50 pm
DrAmine
Ansys EmployeeEnergy source term to be provided in W/m³.
5386
3375
2471
1310
1022
