How to press “Enter” in a Journal File
    • CMHR
      Hi!
      I am currently writing a journal file to extract the cp distribution on an aerofoil. Initially, I created an iso-surface to make a cut plane, than I wrote a command to extract the Cp distribution of that plane/surface. However, this seems to work fine in the command prompt (console) of the GUI but not really in the journal file.
      The main reason to this is because i need to press enter whenever there is a selection of zone or surface in the gui but I can not do the same in the journal file. Is there any way to write or tell fluent to press enter?
      I have attached some images that might help you understand my jou file and the same thing in the command prompt.
      Thank you,
      CMHR
      Picture of the JOU file:
    • CMHR
      Hi!
      I found out how to do it, it is just ().
      Thanks
      Forum Moderator
      () closes a list out. Most of the other commands should automatically trigger the next command.
