How to prevent deformation between bonded structures?
    • emily_maci
    • Rameez_ul_Haq
      ,if that is how you want to model the connection between the two, insert a contact tool (right click the connections in the tree), insert status, and check if the two bodies are sticking. If not, increase the pinball radius to finite value of like 5 mm. Recheck the contact status.n
