December 7, 2022 at 4:18 pm
Ben Dietrich
SubscriberHello all,
I am currently attempting to set up a simulation for simple stress/strain responses to loads on a metal part, however when I import my geometry to Workbench's geometry module (Workbench 2020 R2) and open it up in Spaceclaim, the surfaces that were marked out as the loading areas were combined with the surrounding surfaces. Shared Topology is set to None, and I have opened up the geometry in Hypermesh to confirm that yes the surfaces are there. Does anyone know what is causing Spaceclaim to automatically merge these surfaces, or otherwise how to prevent this from happening?
A section of the model opened in spaceclaim;
The same section opened in Hypermesh;
Any help figuring this out would be incredibly appreciated, thank you!
December 8, 2022 at 12:38 am
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2620
2098
1327
1110
461
