March 23, 2021 at 8:11 am
PANDIMANI
SubscriberCAN KINDLY ANYONE EXPLAIN HOW TO DO DISPALCEMNET CONTROL ANALYSIS INSTEAD OF LOAD CONTROL FOR REINFORCED CONCRETE BEAMS ANALYSIS IN ANSYS APDL. AS IN CASE OF FORCE CONTROLLED ANALYSIS, THE COMPRESSIVE STRESS-STRAIN CURVE OF CONCRETE IS TAKEN UPTO ASCENDING BRANCH AND THEN FOLLOWED BY A HORIZONTAL PLATEAU UP TO MAXIMUM STRAIN OF CONCRETE SAY (0.003). HERE, THE SOFTENING EFFECT THAT IS THE DESCENDING CURVE CAN NOT BE TAKEN SINCE IT IS SAID IN THE LITERATURE THAT ANSYS DO OT SUPPORT DESCENDING CURVE THROUGH LOAD CONTROLLED METHOD. BUT IT IS ALSO SAID THAT IT IS POSSIBLE TO CONSIDER ENTIRE (ASCENDING + DESCENDING) CURVE THROUGH DISPLACEMENT CONTROLLED ONE WHICH IS ADVANTAGES OVER THE LOAD CONTROL AND THEIR WON'T BE ANY CONVERGENCE ISSUE AS THAT OF LOAD CONTROL ONE.nkINDLY CLARIFY IF I GO WITH DISPLACEMENT CONTROL HOW DO I CHECK THE APPLIED LOAD OR RESISTED LOAD. ALSO WHAT ARE THE OTHER CHANGES I NEED TO MADE WITH DISPALCEMNET CONTROLLED ONE IN THE NONLINEAR SOLUTION TAB.nKIND REGARDSn -
March 23, 2021 at 1:04 pm
Erik Kostson
Ansys EmployeehinnSo where you apply a load we will then apply an enforced displacement instead - (say using a displacement in WB.Mechnanical, as shown in the image below (yellow marking), or by using D command in APDL).nnIn order to get the equivalent applied force , we can look at the reaction force at the applied displacement (as shown in the image below - yellow marking highlighting the Force Reaction result)nnAll the best.nnErikn
March 24, 2021 at 6:39 am
PANDIMANI
SubscriberSORRY SIR I WANT TO DO DISPALCEMNT CONTROL ANALYSIS OF RC BEAMS IN APDL NOT IN WORKBENCH. KINDLY EXPLAIN HOW TO GET THE POST PEAK CURVES OF LOAD -DEFLECTION PLOT.n -
April 4, 2021 at 5:31 pm
Mshrest2
SubscriberSelect the nodes of location of load and apply displacement in the direction of load using APDL Command (D Command), After you run the analysis, sum of reactions in the selected nodes in the direction of appied displacement give the value of applied reaction.n
Viewing 3 reply threads
Trending discussions
Top Contributors
2678
2120
1349
1136
461
Top Rated Tags
