Discovery Import
Discovery Import
How to project a stl model outline on to a plain
    • mmcgowan
      Hi what is the best way to project to a plain when using a mesh file.
      I want to cut the stl file with a plain delete 1 half then use the lines where it is cut along with details not on that plain.
      Any feedback would be great
    • Naresh Patre
      Hello Mark McGowan
      You can first split the stl using Split Solid tool, then select the edge loop and copy -paste the selected edge loop to get the set of lines where the stl model was split. Please refer below image.
      • mmcgowan
        Naresh Patre
        Hi
        thanks sorted that bit, but I need to project some of the part that does not cut through the plain on to the plain, how do I do that?
        M
      • Naresh Patre
        Mark McGowan
        There doesn't seem a direct way to project parts of stl that don't pass through the plane. below are a couple of options you can try out:
        1. Create another plane passing through the other parts of the stl. Then use the process mentioned earlier to get the edges are splitting the stl part.
        2. Convert the other stl parts to solid body. You can then use project tool to project the solid body on to a surface.
    • mmcgowan
      Hi Thanks for that kinda what I was thinking
      M
