February 27, 2022 at 3:18 am
mosfet
SubscriberHello,
I am designing a CPW transmission line using an anisotropic material(lithium niobate) as the substrate. The wave ports are located in the XZ plane and the dielectric tensor is of the form:
March 8, 2022 at 9:54 pmCharlotte Blair
Ansys EmployeeHi Mosfet One suggestion is to put in a small section of isotropic material as the port then de-embed that amount. As the error stated our tools need to align the port orthogonally with the material.
Regards Charlotte
March 8, 2022 at 10:45 pmmosfet
SubscriberHello Could you provide more details regarding your suggestion? How do I go about de-embeding the extra section?
Thanks!
- Maxwell, HFSS or Q3D?
- Error
2630
2104
1329
1110
461
