How to provide a good and correct loading according to real conditions without modeling electric mot
March 22, 2022 at 6:27 pm
marufyanuar_
SubscriberHello everyone, can I ask a question about my project? I did an analysis of the electric motor bracket, where the bracket supports an electric motor which has weight, torque and force due to chain tension. How to provide a good and correct loading according to real conditions without modeling the electric motor design? Ignore force on the image, only fixed support is correct.
March 22, 2022 at 6:33 pmmarufyanuar_
SubscriberPlease help me sir
March 24, 2022 at 2:43 pmAshish Kumar
Forum Moderator
You can define correct force components and moments. Also, if the force application is at a different location then try using remote force.
Regards Ashish Khemka
March 29, 2022 at 2:03 pmmarufyanuar_
Subscriberthe electric motor specification has a maximum torque of 134Nm, does the dynamic analysis use this value?
Trending discussions- Solver Pivot Warning in Beam Element Model
7592
4440
2953
1427
1322
