May 9, 2022 at 11:01 pm
mriheen
SubscriberMay 16, 2022 at 5:38 amChinmay T
Forum Moderator
If the top and bottom metals are connected through vias then you have assigned the lumped port correctly.
If required, you can also draw a rectangle so that the port touches one of the top metals.
Thanks Chinmay
May 16, 2022 at 11:59 pmmriheen
SubscriberThank you for the confirmation. Appreciate it.
Viewing 2 reply threads- The topic ‘How to provide lumped port for grounded CPW?’ is closed to new replies.
Trending discussions- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3155
1688
1478
