November 5, 2018 at 10:15 pm
sameerfares
SubscriberHi All,
Is there a way in Ansys where i can input the load in pound per foot of surface length? For example, i'd like to put a load on the two green surfaces and the load will be in pounds per foot along the length of the truss or joist members? i think can put the total force on the surface by taking the (load per foot) x( length of the green surface) then use "Force" in Mechanical, but i'd like to know if there is a way to do pound per foot because it will be easier to compare load values with experimental testing.
Sam
November 5, 2018 at 10:47 pm
SubscriberHi Sam,
You can apply Pressure to any face of a surface or solid body. The Pressure will be applied to the area of the face. For flat faces, you can calculate the force applied by multiplying the pressure by the area. The pressure is applied normal to the face. If the area becomes twice as long, the force will double for the same value of Pressure.
November 5, 2018 at 11:00 pm
Sandeep Medikonda
Ansys EmployeeIf it is Force/Unit Length, Can you apply it to just the edge? See line pressure in that case.
Sandeep -
November 5, 2018 at 11:09 pm
sameerfares
SubscriberHi Sandeep,
When i tried to use Line pressure and selected the two surfaces, and apply it in "Geometry", Mechanical doesn't accept. I can't apply to edge because the lineal load is on the top of green surface in my earlier picture. Think of it like a wide flange beam with the load on the top surface of top flange and the load is uniform and in pound per foot. I dont want to compute the total force every time i want to change the unifrom load(pound/ft).
Sam
November 5, 2018 at 11:51 pm
Sandeep Medikonda
Ansys EmployeeSam,
lbf refers to the force. Please see this article.
You might also find this example helpful.
Sandeep
November 6, 2018 at 5:28 pm
November 6, 2018 at 5:30 pm
November 6, 2018 at 7:36 pm
sameerfares
SubscriberI answered my own question about magnitude=0.0803755 *Z .
Thanks!
Sam
November 7, 2018 at 3:15 am
November 7, 2018 at 2:37 pm
sameerfares
SubscriberThank you Sandeep!
2068
1289
1106
459
