July 16, 2018 at 12:49 pm
suraj9735
SubscriberI am trying to simulate for the thermal response (temperature counter) of simple cavity plate of the injection mold because it is very important to temperature range should be within tolerance.
I made a simple cavity and make a cylindrical hole along the length to represent the electric cartridge heating. I made a steady state analysis with constant heat flux input. But now I want to make a thermal transient analysis with periodic heat flux input.
I have the problem in inputting periodic heat flux load as an XML file. I got the error "Either the specified location is incorrect or the source at that location contains no data".
I want to put load as below chart
I also new to this software. Waiting for help. thank you!
July 19, 2018 at 12:46 am
July 26, 2018 at 11:12 am
SubscriberHi Suraj,
I moved your question to a new topic, since this topic is marked as solved.
Some people will not spend time reading solved topics so you might not get all the help you could.
2080
1299
1106
459
