October 16, 2023 at 1:22 pm
Masooma_Qizilbash12
Subscriberhello all,
I want to ask how I know the values to be enter in the initialization tab of ansys fluent package 2020 R2 for turbulanet kinetic energy and specific dissipation rate if i have a beaker and in beaker there is 1%PVA and 0.2 % PEI are mixing at the impeller speed of 5000 rpm total volume of the sytem is 1010 ml 1000ml pva and 10 ml pei.
thank you
regards,
masooma
October 27, 2023 at 12:47 pm
omkar.kulkarni
Ansys EmployeeHello,
You will need some more parameters to calculate the TKE and specific dissipation rate. You can refer the following formulas and calculate it accordingly.
1. TKE=1/2 (ρu′u′)- TKE is the turbulent kinetic energy.
- ρ is the density of the fluid.
- u' represents the fluctuating velocity (the deviation of the local velocity from the mean velocity).
2. ε=2μ/ρ[(∂xj/∂ui)(∂xj/∂ui)]
- ε is the specific dissipation rate.
- μ is the dynamic viscosity of the fluid.
- (∂xj/∂ui) represents the velocity gradient in the fluid, with i and j denoting the different spatial coordinates.
I hope this helps.
Thanks.
October 30, 2023 at 6:05 pm
Masooma_Qizilbash12
Subscriberthank you Omkar for the reply,
I want to know that I have only one velocity of 5m/s how can I calculate the velocity deviation from local velocity to mean what this gradient means also for TDR what is this velocity gradient because in a stirred tank impeller is moving with 5000 rpm only one velocity
I shall be thankful fo the help
kind regards,
masooma
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
