February 28, 2017 at 9:19 am
Nikita
Ansys EmployeeHow can I import a 2D PDF that contains boundary representation data (B-Rep data) into ANSYS SpaceClaim?
July 20, 2017 at 9:50 pm
pgl
Ansys EmployeeANSYS SpaceClaim can import 2D PDF that contains boundary representation data (B-Rep data) directly. No additional licenses are required for the ANSYS Student or other ANSYS Academic products that provide access to ANSYS SpaceClaim.
Note that if B-Rep data is not contained by the 2D PDF, you can first convert the *.pdf to *.jpg and then import that in SpaceClaim for creating new geometry.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
