October 16, 2018 at 10:33 pm
song
SubscriberHow to read a result file such as *.rst, *.rth, *.rmg and *.rfl? This question seems naïve. I have posted one on reading result file issue with binlib.dll subroutines called "Using gfortran compiler to compile demo-files such as ResRdDemo.F against binlib.dll failed". I ask a question on reading result file with GUI here.
I used command "ansys.exe -b -dir directory -i inputfile.txt -o ansys.txt" and ansys completed analysis. I believe that result in "ansys.txt" is correct.
1. When I use command "list->files->binary files->other->header only" to read "file.rst", but result is as following:
DUMP OF FILE= .DesktopbaoworkProject_1methodssetuprun_1m_1file.rst
RECORDS 1 TO 1
RECORD= 1 LENGTH= 100 LOC= 0 KBF= 100 (HEADER RECORD)
SOURCE: ANSYS PROGRAM
UNIT: 12 FILE FORMAT: External
RECORD LENGTH: 16384 FILE SIZE: 72888 SPLIT POINT: UNKNOWN
NUMBER OF DISTRIBUTED MEMORY PROCESSES: 1
NUMBER OF SHARED MEMORY THREADS: 2
CREATION TIME: 19:17:56
CREATION DATE: 10/14/2018
RELEASE: 19.0 UPDATE: 20171214
SYSTEM: WINDOWS x64
PRODUCT NAME: FULL
JOBNAME(1:: file
JOBNAME(12): file
USER: User
TITLE: Bridge Truss Tutorial
SUBTITLE:
UNITS: UNDEFINED
The header format of this result is different from The Standard Header for ANSYS Binary Files. I want to know why? as a user, how to read useful results from binary result files if the header format is various or random. In addition, I can not find any useful results in this file.rst.
2. When I use command "list->files->binary files->other->all records" to read "file.rst", it shows warning:
"Result file written in parallel -AUX2 DUMP may abort. Use PTR,LOC,BASE to view the records in that case". I do not know how PTR,LOC,BASE to view the records because I cannot find how on any manual.
Any help or comments will be appreciated.
Song
October 18, 2018 at 11:10 pm
Sandeep Medikonda
Ansys Employeewhat software are you using to read the file?
Isn't it Mechanical or APDL? It would typically have to be either of these.
October 18, 2018 at 11:24 pm
song
SubscriberHello Sandeep,
Thanks for your response. I use Mechanical APDL.
Song
October 19, 2018 at 3:59 pm
Mike Rife
Ansys EmployeeSong
When you use MAPDL to list the result file header like that, it is interpreting the numerical header into a human readable form for the users convenience. If you really want to find out the numerical values please see the following:
ANSYS 19 Help -> Mechanical APDL -> Programmer's Reference -> I Guide to Interfacing with ANSYS -> Chapter 1.1.2 The Standard Header for ANSYS Binary Files. Also Chapter 1.2.3 Results File Format
In the result file there is a standard binary file header, then a header specific to the result file.
Mike
October 24, 2018 at 4:43 am
song
SubscriberHello Mark,
thanks for your time. it is resolved.
Song
2066
1279
1096
457
