November 26, 2022 at 4:47 am
Ivan Mendez
SubscriberHey all
I'm trying to create a UDF which reads from a SQL file the x,y,z coordinates of a point, and then I want to find the closest cell of that point. After looking around, I found that CX_Find_Cell_With_Point can find the cell given a point. The problem is, I can't get any information of that macro anywhere.
How do I create a UDF to read from a SQL database and find the closest cell? is there another way of doing this besides CX_Find_Cell_With_Point?
December 8, 2022 at 5:16 pm
Ansys EmployeeI've been pointed at this thread too: some people obviously think I need more work... ;)
As per the comments on https://forum.ansys.com/forums/topic/how-do-i-add-a-sqlite-header-in-my-udf-file/ the SQL bit will be more complicated. Using a text file with columns for x, y, z and then a file read routine will be significantly easier.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
