Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
How to read out the rotor position in Maxwell
    • Sebastian
      Dear ANSYS Community,
      I have built a model of an electric machine in ANSYS Maxwell with external windings in Simplorer. Now I want to control the machine in the dq System. Therefore I need the Rotor position as an variable in Simplorer (due to this it should be a global variable?) How can I read out the rotor position in maxwell and import it to my Simplorer Winding design?
      Thank you for your help!
      Regards
    • Minxiang Wu
      Dear Sebastian,
      There are some examples about co-simulation of Maxwell and Simplorer in the example library. Click File > Examples > Simplorer > Components > Interfaces > Maxwell > TR-TR > 2D. This might be a good reference for you. You can also explore the other examples in this directory. Please let me know if you have more questions.
      Thank you.
      Best Regards,
      Minxiang
    • Sebastian
      Dear Minxiang,
      Thank you very much for your reply. It helped me a lot to do an Co-Simulation. But now I have a problem regarding the dq-Currents in the Simplorer. I formalized the problem and attached the file here:
      https://forum.ansys.com/forums/topic/co-simulation-motion-seems-not-to-be-working/
      Do you have an idea?
      Thank you very much!
