how to read results at center of a plate ANSYS workbench?
    • elhamasadi
      Hi. Is there any war to read results (deformation and Von-Mises stress) at center of a plate ANSYS workbench?n
    • Govindan Nagappan
      @elhamasadi nCan you provide more details regarding this questions?nIf you need the results at a specific point at the center of a shell model, you can use the Probe tool to get the results. Check this linknStructural Probes (ansys.com)nIf you have a solid model and if you are trying to get results at a cross section, check using construction geometry(surface) : Surface (ansys.com)nYou can plot results on the surfacenn
    • elhamasadi
      nThank you, I could accomplish it .n
