March 8, 2021 at 2:54 am
Snow1Runner
SubscriberI am trying to take some screenshots for a paper I'm working on and would like to get rid of the grid lines. I have disabled the "Show Sketch Grid" on the Display ribbon but I can still see grid lines in the background.
Thank you very much!
March 8, 2021 at 3:55 amKeyur Kanade
Ansys EmployeeIf this is not working you may want to play with File - SpaceClaim Options - Detailing - Modular Grid. Here you can change different parameters. You may want to check grid intervals and intervals per grid line. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynMarch 17, 2021 at 2:11 pmRoman8
Ansys EmployeeHi Snow Runner,nThe gridlines will still be shown but when you save an image you won't see them. You can control what gets saved into images under settings -> appearance.nRomannViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2610
2088
1321
1108
459
