How to remove h5 extension
    • i.tamunodienye2
      Please how do i remove .h5 extension in case and data files of Ansys fluent. I am using version 2022R2
      The HPC does not support .cas.h5 and .dat.h5. This is a serious problem.
      I tried making legacy default in "Preference" but this did not change.
      Please i need help.
      Thanks
    • Keyur Kanade
      Yes, you can change it in Preference.
      Also you can use TUI commands to write case and data files.
      / file write
      Keyur
    • i.tamunodienye2
      Hello Keyur,
      I have done so but it's coming out as .cas.h5 and .dat.h5.
      Please i need help
    • i.tamunodienye2
      NOTE: Parallel data (.pdat) files are no longer supported. The ANSYS common fluids format (CFF) is recommended instead; it has optional modes that allow parallel I/O.
    • i.tamunodienye2
      The above message appeared after i typed command file/write-case
      The preferences are per system, so if the HPC isn't seeing your local machine you may need to set preferences on that machine too. Preferences can be adjusted by the TUI so you may find a couple of extra lines in the run journal are necessary.
    • i.tamunodienye2
      Hi Rob,
      Thanks for your response.
      Over the years the below journal TUI steps had been working for me with 2020R2 version. There's no h5 extension
      And get results like below
      With the 2022R2 version i did as shown below
      The simulation runs but no output files.
      I tried again to adjust like below
      Its the same thing. The simulations runs but no output files.
      I have never experience this issue when i was using .cas and .dat files only.
      Please i need help in case  i missed some lines.
      Thanks
      I always use /file/rc or /file/rcd  and never rely on the TUI menu being in the root level. Other than you not needing to add .dat.h5 to the name it looks OK.
      However, depending on models, /s could be /server or /solve and then /d can be  /dpm-update, /dual-time-iterate or return an error.
    • i.tamunodienye2
      Thanks for response.
      In essence i should try to know what /s and /d imply in 2022R2 model. Could it be the issue?
      I have also tried just with .cas and .dat without adding the .h5. It still ran but no output files.
      Possibly. The use of short cuts can be a little dangerous as some can represent the wrong command: we've had a few hiccups over the years with these and I expect them to continue!
    • i.tamunodienye2
      Also, this is 1-way FSI simulation. Is there any line in the fluent journal specifically for fluid-structure interaction case?
    • i.tamunodienye2
      Note, I am doing 1-way FSI directly in Fluent.
      That may depend on how you're linking the code(s). If you're just spitting out data for Mechanical to use later on you may just need legacy data files.
    • i.tamunodienye2
      I did everything in Fluent.
      OK, use the h5 format and either reduce the autosave frequency or retain fewer files. I’d switch to running standalone so I could control things more easily.
      Edit, forgot to add, make sure you save case and data.
Viewing 14 reply threads
