March 18, 2022 at 1:21 pm
davidl
SubscriberMay 29, 2022 at 12:07 pmNavya C
Ansys EmployeeHi I think it is only showing the area available for impregnation. It is negative in your screenshot, maybe the slot area is already overcrowded with conductors.
We are not defining any materials for impregnation. Are we?
Regards Navya
May 31, 2022 at 1:35 pmDeyu Li
Ansys Employeepotting is defined in geometry tab->axial->EWdg Cavity, you can set it as "not Potted".
- Maxwell, HFSS or Q3D?
- Error
3862
2639
1859
1254
600
