May 8, 2023 at 5:28 pm
leosibarani1
SubscriberHi everyone, i need some help in my mini project that is to simulate the PEMFC model.
I have a problem of stair-steppping as the picture i show here. I need to know how to remove this stair-stepping in my volume mesh. For the invormation, i tried to reduce the number of cells generated in volume mesh by made a local sizing in some area which made the higher of face size in surface meshing. Before i did the local sizing i got 24 locations of stair-stepping, and after local sizing i got 28 locations of stair-stepping. I also use share topology in this case.
Thank you in advance, your advice will be very meaningful for me.
May 11, 2023 at 2:32 am
Muhammad Rizky Pratama Hakim
SubscriberHello Leo,
Usually, the easy way to remove stair-stepping mesh is to reduce the element size of the surface mesh because stair-stepping size usually occurs in the transition between boundary layer mesh and outer mesh.
- Features of the check case
- Does anyone know what this is caused by? – Cyclone Separator Simulation (CFD)
- Hydrostatic pressure simulation failure on a simple structure like a large aquar
- Error Floating Point Exception
- Heat transfer radiation through glass
- Room with Air-Conditioning Vents
- real fundamental difference in true tension body and engineered tension
- Convergency in mass flow rate
- Function mess balance in fluid flow
- Viscous Models
5364
3363
2471
1310
1018
