October 26, 2018 at 3:04 pm
October 26, 2018 at 3:24 pm
FrankD
Ansys EmployeeMany ways:
1) Make planes through the edges (that form the straight-curved body pieces) of the orange weld body and split (or Combine>Cut) to get them separate, and deletable.
2) In this view, sketch surfaces that encompass the curved pieces, and pull>Cut them through the body, deleting the Curved pieces
3) Delete the faces of the curved pieces (this would be easier if you Open Component into a new window tab) and fill the faces left over in the straight pieces, making it solid again.
I am sure there are other, longer ways. Same geometry at the end though.
October 26, 2018 at 3:38 pm
sameerfares
SubscriberThank you Frank for the different ways. I used #1 and it worked.
Sam
October 26, 2018 at 4:19 pm
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2630
2104
1327
1110
461
