July 29, 2019 at 6:50 am
Azim07
SubscriberHere i have a UDF which Shows the undeclared variable error in line 6. How can i remove this?
#include "udf.h"
DEFINE_PROPERTY(cell_density,c,t)
real rho;
real T = C_T(c,t);
rho = 885/(0.0008(temp-321.35)+1);
C_UDMI(c,t,0) = rho;
return rho;
July 29, 2019 at 1:59 pm
Ansys EmployeeI find deleting the line to solve many problems. Read the error carefully, and tell me which variable is undefined.
July 29, 2019 at 2:24 pm
rachels1001
SubscriberI may be wrong, but is the "temp" variable defined anywhere?
July 30, 2019 at 4:43 am
Azim07
SubscriberI just need to define the density in the way of following Equation
rho = 885/(0.0008*(t-321.35)+1)
How can i easily enter it ?
July 30, 2019 at 11:51 am
rachels1001
Subscriberby using the macro C_T, you are finding the temperature for the cell that you are passing into the UDF, and you are defining this temperature as T. If this is the temperature that you want to evaluate density by, the line should read
"rho = 885/(0.008*(T-321.35)+1)"
not "rho = 885/(0.008*(Temp-321.35)+1)"
July 30, 2019 at 2:33 pm
Ansys Employeecvelikonja: correct. T is defined, temp is not so will cause an error when used in the code.
Note, UDFs may be case sensitive so always consider this too. T is also a slightly dangerous letter to use when you're using t for thread in Line 2.
July 31, 2019 at 9:34 am
Azim07
SubscriberThank you very much Gentleman......
I am getting Floating Error in the following UDF of viscosity......
#include "udf.h"
DEFINE_PROPERTY(cell_viscosity,c,t)
real mu;
real temp=C_T(c,t);
mu =(0.00727)+((((-8.6022)+(1871.3/temp)+(0.0152*temp)-(0.000012043*temp*temp))-(0.00727))/1+(exp((10/343-temp)*(temp-321.35))));
return mu;
July 31, 2019 at 10:18 am
Ansys EmployeeI doubt the floating point is in the UDF: it'll be the value produced by the UDF. Plot the value of your function against temperature and see what it produces.
2656
2120
1345
1118
461
