January 16, 2023 at 5:31 am
Sjoerd Huurdeman
Dear Support,
I received an 3D model of the client. When I open this model in Trutops design there are brown surfaces instead of grey. How can I repair brown surfaces in Spaceclaim / Trutopsdesign? As long as the surfaces are brown, I am not able to make a flat pattern!
January 16, 2023 at 7:46 am
Devendra Badgujar
Forum ModeratorHello Sjoerd Huurdeman
Please check the attached repaired model. The issue was with the corner 1 which was not getting assigned as junction. For Junction 2 it was straightforward to assign as the corner was fine.
For corner 1 issue, I had to split the body into two then used pull/move operations to create a proper corner to assign a junction. I was able to unfold to create a flat pattern.
Let me know if you have any questions on this.
Regards.
January 16, 2023 at 8:37 am
Sjoerd Huurdeman
Hi Devendra,
Thanks you for your answer. I have 2 adiitional questions:
- How did you manage to make the brown surface into grey?
- What is the meaning of a brown surface?
January 16, 2023 at 9:58 am
Sjoerd Huurdeman
Besides that I have the problem concerning not fully flat: (see picture)
January 20, 2023 at 1:19 am
Devendra Badgujar
-How did you manage to make the brown surface into grey?
If you look at the corners where you need junctions to flatten/unfold the Sheetmetal is not proper and has some issues. I have attached a short video demonstrating the steps to repair this corner and to create a proper bend at that location.
It is just saying that it has not converted to Sheetmetal from Solid properly.
Please check the attached video for the same. Thank you!
Let me know if you need any further assistance.
Regards.
January 23, 2023 at 10:04 am
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7742
4504
2971
1449
1322
